Inventor Forum
Air Trap Analysis 2012
4 REPLIES 4
ericjed13
573 Views, 4 Replies
Somebody help me.
I can't find the air trap analysis for 2012. it says it does not run such analysis in 3D. For some parts however, it did run. Is there any way to solve this problem???
4 REPLIES 4
abakharev
in reply to: ericjed13
Well, run the 2.5D flow analysis on the surface mesh defined by the 3D mesh. It should show the airtraps.
ericjed13
in reply to: abakharev
Okay, and how do i do that exactly? :S
abakharev
Select your study.
Right click on the 3 D Mesh label:
In the Pull-down menu select Set Mesh Type.
Choose Dual Domain.
The label now is is Dual Domain Mesh. If the surface mesh were present, you would see some some none zero number of elements. If the surface mesh was not stored in the study you would see 0 elements:
Right click on it once more and select "Generate mesh".
After meshing is finished start the analusis and enjoy the Air Trap plot.
ericjed13
Wow! Thanks for that!
