Please forgive the length of this ...
I hope the attached file shows what I'm trying to convey; if not, I can elaborate further.
I'm trying to "connect" two fittings from two different routes. That is, based on the attached file, I want a node of the upper route to stay coplanar with a node from the lower route. Knowing that a plane can't be defined by only two points, I want the other condition to be that the resultant third route be perpendicular with the other two. When editing a route (this is a Wish List item), it would be really nice if I could simply pick a route and tell it that I want it to remain vertical (or orthogonal to a plane or something). Route geometry should have the same constraints available to it that 2D sketch geometry does.
I've tried everything. I was finally able to define a node on the upper route based on a node on the lower route, but it took a construction line to do it. I can then get the node in question to move from point 1 to point 2. But as soon as I do that and click Update, the third route skews because only the top of it moves. The opposite end stays grounded, and I see no means of ungrounding it.
Not having a vertical option available to me, is there a means of doing what I'm (hopefully successfully)describing?
If it helps, the upper horizontal route and the upper vertical route are separate routes within the same run. The work plane is also part of that same run. The construction line, however, is part of the lower run.
Kevin
