Garf / Neil,
Yes, Autodesk knows the issue and we are looking into it.
There is a limit for the number of add-in command IDs. When the limit is
reached by adding more add-ins, you will see commands missing. Simple
workaround for now is unloading add-ins you donot use to free up command
IDs. For example, if you work on Tube and Pipe project and will not use
Cable and Harness at all, you may unload Cable and Harness or any other
add-ins.
Best regards,
Gary Tang
Autodesk Inc.
"Neil Munro" wrote in message
news:4834447@discussion.autodesk.com...
Try unloading some of the other add ins.
This add-in conflict issue is getting to be a issue in a number of areas, I
hope Adesk can find a fix.
Neil
wrote in message news:4834440@discussion.autodesk.com...
Hi All,
Has anyones else noticed the right-click menu's in AIP are missing options?
Most noticable is the Point Snap option!
When I try to create a new route and right-click expecting to see Point
Snap as I did in AIP9, it's not there.
Also - when I select the start edge for my route, right-click to chage
direction the option isn't there.
Has anyone else seen this behaviour?
Do the guys at Autodesk know anything about this?
Cheers
Garf
AIP10
Dell M60
NVidia GoFX 700 with 67.22
Win XP Pro sp1
1Gb RAM
