I can not get the colors set to material in the content center. These are the steps I followed.
1) start new .Ipt => finish sketch.
2) go to "material browser"=> click "create new material in document"
3) edit new material => name "Steel Green " => generic color choose green. => OK.
4) add new material to your custom library or to the "Inventor Material Library". (custom library is in project file)
5) close document
6) go to Tools => Editor => Family Table => Column material Properties => choose "Steel Green".
7) Ok, publish OK.
😎 new assembly => place from content => get the new material.
9) check properties. Material is Assigned but not the color
What am I doing wrong. Does anyone have a solution?
Cheers Boely
I could able to reproduce the behavior. I have logged it with our development team for further investigation. I will keep you posted on the updates.
I am having this same issue, i can't assign any material colours to my model?
Material has been assigned as you can see in the attached picture but the tick button is greyed out meaning I can't confirm the colour that should be assigned
