(AIP - 2013) I put my templates on a central workstation. I configured the project files (.ipj) on the other computers (folder options-templates) When I click 'new' to start a part or what ever, the templates are not found. The dialogbox is empty. I also tried to change the standard location for the templates. (appl.options - file - templates) Same result, the templates are not found. Please help. (AIP 2012 works ok)
Not knowing much about your network, but you would have better luck setting up your templates directory on your server.
As I said, the AIP 2012 release worked perfect. Just a simple network, should working without any problem.Why not after installing 2013? Clean install of course.
