In this part there are 2 flanges, kind of. I just removed one so that you can see but later I'll remove both. But I used "Delete Face" to get rid of it but it left a hole open where the flange used to be. How do I stitch that up so to speak so I can fold out the model? I tried using "Patch" and "Stitch" but it didn't do anything.
I'm assuming this is the problem because when I go under "Sheet Metal" there is no fold out option.
Any ideas?
Solved by AmarD90. Go to Solution.
You've got to try and use heal otherwise it creates a shell as you have now after that delete face.
Delete that face first , then the rest. dxf attached
Delete that small face, with the transition radius first, then do the whole flange.
What is the defining feature of sheet metal?
Hint: (uniform thickness)
Also, you have a Contour Roll type feature in that part. (deformed)
...and, have you installed Service Pack 2 for 2014?
You need to get rid of that Contour Roll as JD poited out but you can't do it in one delete face operation. If you first remove that small transition face you can then do the rest of the roll.
See attached example.
Often, another solution is to Thicken only surface to faces that you want to retain.
Not sure why you used Derived Component - but in cases where I do use Derived Component I derive as a surface body rather than as a solid body and Thicken what I what to keep as the sheet metal part.
