How about $100 for a graphics card? PNY 550XGL
http://www.emicrox.com/eShop/product.aspx?advanced=1&cid=10020&attr=AGP&pid=944777
Ram might be fine - it all depends on what you do with it. The good thing
is you can make that decision down the road when you find out you're running
against a wall.
I'd leave the CPU - but of course the old "depends on what you do with it"
applies. If you're making jigs and fixtures, I'd think it's fine. If
you're doing surfacing, lots of derived parts, arrays, etc... but again,
you can decide later on if you find yourself hitting that wall.
"Ltspd" wrote in message news:401d1ddb_2@newsprd01...
| I need some advice / suggestions:
| I will soon be setting up a temp office and workstation at a company I do
a
| lot of work for, I currently am a sub for them and will continue to be so.
| I CAN NOT afford a high dollar system to put on site. I have an older
| system I am planning on using, AMD 2.0, 768 pc2100, Biostar m7mia M-board
| standard HDD no raid.
| What I need suggestions on are as follows:
| 1) low cost video card. The biostar M-board is 4x agp (agp pro.....) I
can
| pick up some Ti GF4 cards cheap as well as the FX 5000 series. I would
like
| to spend less than 200, the cheaper the better. Dual output is a
possible,
| I run dual LCD's on my main system and may go this route again, if not it
| will be a 21" or larger CRT. Nothing but Nvidia.
| 2) would you bump the RAM to compensate for the lower end VC? I cant run
| anymore than pc2100 I think, and I am not 100% sure if the biostart MB
will
| handle any more than 1 gig total, so I would only be increasing 256mb, not
| much but it might make a difference.
| 3) Leave the cpu or bump up some?
| Once again I will stress money is a major factor. I know that good
systems
| in the long run pay for themselves, but I HAVE a high end system in my
home
| office. This off site office will only be used by me around 20 hours per
| week, and I will more than likely bring work home on occasions.
| Thanks
| Paul
