Inventor Forum
advanced surface
11 REPLIES 11
Message 1 of 12
marcin.blaszczyk
561 Views, 11 Replies
advanced surface
hello there,
I'd like to connect border shape with a point which is few milimeters above flat surface (see fig 1,2) but I do not want to do it as it was presented on fig.3
it should be connected smoothly, something as it was presented on fig 4 & 5 if you know what I mean
it should like a fragment of a really big ball which part of surface is smoothly fading down
how to set advanced extrusion options? I can not figure it out
Tags (1)
11 REPLIES 11
Message 2 of 12
LT.Rusty
in reply to: marcin.blaszczyk
What you need is loft, not extrude.
Take a look at my attached file.  You might need to do another extrude afterwards, to cut away some overhanging stuff, but this should give you an idea of how to do what you're trying to accomplish.
Rusty
Message 3 of 12
marcin.blaszczyk
in reply to: LT.Rusty
that was fast, thanks! i'm checking
Message 4 of 12
LT.Rusty
My computer is busy thinking about a whole bunch of things right now, so I don't really have anything better to do for a few minutes.  🙂
Rusty
Message 5 of 12
JDMather
@marcin.blaszczyk wrote:
it should like a fragment of a really big ball....
If it is really part of a spherical ball, then I would Thicken/Offset a trimmed Revolved Surface rather than do a Loft.
There are a number of surfacing tutorials in my signature.
Most of them except the Vacuum Tutorial are a little out of date.
The CADWhisperer YouTube Channel
Message 6 of 12
marcin.blaszczyk
in reply to: JDMather
"If it is really part of a spherical ball, then I would Thicken/Offset a trimmed Revolved"
can you extend it a little bit because Loft option is not completely satisfying me regarding this shape?
Message 7 of 12
JDMather
If you are asking for my help you will have to attach an ipt file here.
Message 8 of 12
LT.Rusty
Is this closer to what you are looking for?
Rusty
Message 9 of 12
marcin.blaszczyk
ok, here's a file
 sphere constraint should be where the point is (on additional plane)
thank you
Message 10 of 12
LT.Rusty
what's the diameter of the sphere you want to use?
Rusty
Message 11 of 12
JDMather
Sketch1 doesn't have any dimensions?
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Message 12 of 12
marcin.blaszczyk
Lt Rusty - extended to sphere file is what I was looking for! THANK YOU
