Inventor General Discussion
marcin.blaszczyk
Message 1 of 12 (291 Views)
advanced surface
291 Views, 11 Replies
01-16-2013 09:47 AM
hello there,
I'd like to connect border shape with a point which is few milimeters above flat surface (see fig 1,2) but I do not want to do it as it was presented on fig.3
it should be connected smoothly, something as it was presented on fig 4 & 5 if you know what I mean
it should like a fragment of a really big ball which part of surface is smoothly fading down
how to set advanced extrusion options? I can not figure it out
Is this closer to what you are looking for?
LT.Rusty
Message 2 of 12 (287 Views)
Re: advanced surface
01-16-2013 10:02 AM in reply to: marcin.blaszczyk
What you need is loft, not extrude.
Take a look at my attached file.  You might need to do another extrude afterwards, to cut away some overhanging stuff, but this should give you an idea of how to do what you're trying to accomplish.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Workstation: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
marcin.blaszczyk
Message 3 of 12 (285 Views)
01-16-2013 10:06 AM in reply to: LT.Rusty
that was fast, thanks! i'm checking
LT.Rusty
Message 4 of 12 (283 Views)
01-16-2013 10:07 AM in reply to: marcin.blaszczyk
My computer is busy thinking about a whole bunch of things right now, so I don't really have anything better to do for a few minutes.  :smileyhappy:
JDMather
Message 5 of 12 (281 Views)
01-16-2013 10:13 AM in reply to: marcin.blaszczyk
marcin.blaszczyk wrote:
it should like a fragment of a really big ball....
If it is really part of a spherical ball, then I would Thicken/Offset a trimmed Revolved Surface rather than do a Loft.
There are a number of surfacing tutorials in my signature.
Most of them except the Vacuum Tutorial are a little out of date.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
marcin.blaszczyk
Message 6 of 12 (273 Views)
01-16-2013 10:33 AM in reply to: JDMather
"If it is really part of a spherical ball, then I would Thicken/Offset a trimmed Revolved"
can you extend it a little bit because Loft option is not completely satisfying me regarding this shape?
JDMather
Message 7 of 12 (267 Views)
01-16-2013 10:36 AM in reply to: marcin.blaszczyk
If you are asking for my help you will have to attach an ipt file here.
LT.Rusty
Message 8 of 12 (262 Views)
01-16-2013 10:40 AM in reply to: marcin.blaszczyk
marcin.blaszczyk
Message 9 of 12 (256 Views)
01-16-2013 10:43 AM in reply to: JDMather
ok, here's a file
 sphere constraint should be where the point is (on additional plane)
thank you
LT.Rusty
Message 10 of 12 (252 Views)
01-16-2013 10:46 AM in reply to: marcin.blaszczyk
what's the diameter of the sphere you want to use?
