Inventor Forum
.adsklib
4 REPLIES 4
3569 Views, 4 Replies
.adsklib
Hi There,
Is there any way we can use .adsklib (library file from inventor) from inventor in 3ds max as mateliarl library???
Please help me with this.
Thanks..
4 REPLIES 4
To pile on this question, can I export a DWG 3D file from Revit and provide a person using 3D Max the adsklib file and have the materials mapped?
we cant use .adsklib in max but I found a way to get custom inventor materials to 3ds max matelrials and to layers
we have to use STANDARD AUTODESK MATERIAL items.
Copy a STANDARD AUTODESK MATERIAL and remane it required custom name and flick with changes you want.
And when you open the Inventor file with custom materials applied in 3ds max, you will see the Autodesk standard material name in layers and you can do from there
If anybody want a detail procedure reply me.
mitcham_boy
Hi ADNpati ..
Let me see if i understand correct ..
So i rename and edit a standard material to make it customised. When i open the file in 3DS i lose the customisation but the original standard material definition is retained.
Have i understood correct?
in reply to: mitcham_boy
Hey,
Yes, thats correct. you will see Autodesk Standard Material name in Autodesk 3ds max Layers.
If my solution seems to remedy your problem, Some KUDOS..!!
