Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<huycke> wrote in messageCan
href="news:6157445@discussion.autodesk.com">news:6157445@discussion.autodesk.com...
anyone tell me anything about the adsk file extension which is to be coming
out with inventor 2010? What are its's capabilities,
benefits?
"Dennis Jeffrey" <
href="mailto:djeffrey@teknigroup.com">djeffrey@teknigroup.com> wrote in
message
href="news:6157973@discussion.autodesk.com">news:6157973@discussion.autodesk.com...
I tested the file transfer in 2010. It appears that Revit
Structure 2010 x64 does not support the adsk format.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008
SP3, AIP 2009-SP1 PcCillin AV
HP zv5000 AMD64 2GB - Geforce Go 440,
Driver: .8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
<Mark_Flayler> wrote in messageWhen
href="news:6157991@discussion.autodesk.com">news:6157991@discussion.autodesk.com...
Patrick and I said Revit, what we meant was Revit MEP
"Dennis Jeffrey" <
message
href="news:6159731@discussion.autodesk.com">news:6159731@discussion.autodesk.com...
The adsk file does not open in Revit MEP 2010 either. I
get the same error message as I did in Revit Structure 2010.
Expert
Expert.
AIP 2008
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT
512MB
"Patrick Miller (Autodesk)" <
href="mailto:discussion.support@autodesk.com">discussion.support@autodesk.com>
wrote in message
href="news:6159856@discussion.autodesk.com">news:6159856@discussion.autodesk.com...
I do not have Revit installed to try it. I will
try to find an answer for you. Until then, I'm wondering if there is an import
option as that is the intention - import the assembly into a building model. I
don't think it is a straight open operation.
Patrick Miller
Autodesk Manufacturing Industry
Group
Technical Publications - Subject Matter Expert
Novi, MI
"Dennis Jeffrey" <
in message
I get the same error message as I did in Revit Structure 2010.
Expert
Expert.
AIP 2008
512MB
"Dennis Jeffrey" <
message
href="news:6159860@discussion.autodesk.com">news:6159860@discussion.autodesk.com...
Here's a couple images that illustrate the issue.
The only function supporting the.adsk format is Open, as far as I can
tell.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Manufacturing Implementation Certified Expert.
AIP 2008 SP3, AIP 2009-SP1 PcCillin AV
xp64
sp2, XP Pro SP3, Windows XP Silver Theme
wrote in message
import option as that is the intention - import the assembly into a building
model. I don't think it is a straight open operation.
Patrick Miller
Group
Novi, MI
"Dennis Jeffrey" <
wrote in message
either. I get the same error message as I did in Revit Structure 2010.
Expert
Expert.
AIP 2008
512MB
wrote in message
href="news:6161655@discussion.autodesk.com">news:6161655@discussion.autodesk.com...
Sorry for the long delay. I found that
there is a defect logged (1202491) and the hotfix should be released soon.
Unfortunately, there is no work around. Sorry for the
inconvience.
Patrick Miller
Manufacturing Industry Group
Expert
Novi, MI
"Dennis Jeffrey" <
in message
issue. The only function supporting the.adsk format is Open, as far as I can
tell.
Expert
Expert.
AIP 2008
xp64 sp2, XP Pro SP3, Windows XP Silver
Theme
wrote in message
will try to find an answer for you. Until then, I'm wondering if there is
an import option as that is the intention - import the assembly into a
building model. I don't think it is a straight open
operation.
Patrick Miller
Group
Novi, MI
"Dennis Jeffrey" <
wrote in message
Expert
Expert.
AIP
9800GT 512MB
