Inventor General Discussion
Distinguished Contributor
huycke
Message 1 of 36 (1,734 Views)
adsk file format
1734 Views, 35 Replies
04-07-2009 06:31 AM
Can anyone tell me anything about the adsk file extension which is to be coming out with inventor 2010?
What are its's capabilities, benefits?
JDMather
Message 2 of 36 (1,734 Views)
Re: adsk file format
04-07-2009 06:45 AM in reply to: huycke
What file extension? Can you be more specific?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
mcgyvr
Message 3 of 36 (1,734 Views)
04-07-2009 06:51 AM in reply to: huycke
someones been misinformed.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
huycke
Message 4 of 36 (1,734 Views)
04-07-2009 06:53 AM in reply to: huycke
Yes, I was in a meeting with an Autodesk Rep last week and while discussing the upcoming release of Inventor 2010 I asked if in the new release of both Inventor and REVIT it would be possible to import in REVIT native IPT files from inventor and keep the parametric intellegence.
He said...there will be a new adsk file format which will be more...."robust", ....that is all I know.
*Dennis Jeffrey
Message 5 of 36 (1,734 Views)
The file extensions are the same, and no, they will not be
backward compatible, just like all the other modelers.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
.8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
**Master
BMiller63
Message 6 of 36 (1,734 Views)
04-07-2009 07:21 AM in reply to: huycke
*.ADSK is an exchange file format used in the AEC Exchange part of Inventor 2010 to get products out to Revit. In Revit the *.ADSK file format is used to author files for use in 3D Civil and so on.
Look up AEC exchange in the help for 2010 for more info.
Mark_Flayler
Message 7 of 36 (1,734 Views)
04-07-2009 07:22 AM in reply to: huycke
The new .adsk extension is done through the AEC Exchange Application inside Inventor. The adsk provides more streamlined dumping to Revit Families.
Mark Flayler - Senior Application Engineer
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
*Dennis Jeffrey
Message 8 of 36 (1,734 Views)
04-07-2009 07:35 AM in reply to: huycke
Sorry, forgot that one.... :smileyhappy:
Expert
Expert.
AIP 2008 SP3,
.8185
*Patrick Miller \(Autodesk\)
Message 9 of 36 (1,734 Views)
04-07-2009 12:28 PM in reply to: huycke
As some stated, review the Help for AEC Exchange to
read about .ADSK files. This file format allows you to share Inventor data with
Revit MEP or AutoCAD MEP. The format includes the 3D solids, 2D views, AEC
Exchange connector information, and meta data. When opened in Revit or AutoCAD
MEP, that application only uses what is supported from that file.
If exchanging data with Revit or AutoCAD MEP, don't
forget to use shrinkwrap to simplify your data. It makes for smaller file sizes
and the MEP applications typically don't need the detail that Inventor
needs.
Hope this helps.
Patrick Miller
Autodesk Manufacturing Industry
Group
Technical Publications - Subject Matter Expert
Novi, MI
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Can
out with inventor 2010? What are its's capabilities,
benefits?
*Dennis Jeffrey
Message 10 of 36 (1,734 Views)
04-07-2009 12:41 PM in reply to: huycke
I tested the file transfer in 2010. It appears that Revit
Structure 2010 x64 does not support the adsk format.
Expert
Expert.
AIP 2008 SP3,
.8185
