Thank you.
I think sometimes it's preferable to do a local install of Content Center
just in case the server goes off.
Anyway, the question was for an EDU license of AIP2008, so the students have
the Content Center locally.
Razvan Stancu
"Dennis Jeffrey" wrote in message
news:5653776@discussion.autodesk.com...
If you are doing a local install of Content Center, Yes.
Been there, have had to do it many times. If you have a large deployment,
burn a few copies of DVD-1. Either Siries or Pro #1 will do the job.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
"Razvan Stancu" wrote in message
news:5653520@discussion.autodesk.com...
I made several deployments for AIP2008 NLM. In the deployment options the
ADMS2008 doesn't appear and nor is reflected in the client installation.
I have previously installed IIS. Am I doing something else wrong or that's
the way it is? Do I have to install ADMS and Content Center from DVD
directly on client workstations?
Razvan Stancu
Mechanical Application Engineer
