Inventor Forum
Adjusting Assemblies Take 2
2 REPLIES 2
pajamas4
202 Views, 2 Replies
Hello
Is there a way to adjust the assembly and the parts automatically adjust as well??
I'm not sure if I"m doing this right.
Here's what I did so far. (Attachment with pictures and steps)
This is an assembly file of a 10' trex rafter that goes to a pergola.  Inside of the rafter is an aluminum tube.
What I'm trying to do is save and replace component to make it whatever length (ex: 12') and make the aluminum tuber extrude itself without replacing or saving it.
Picture 1: What I did as fasr was I created (place component)
Picture 2: I drew what I wanted.  Right click on the component and the sketch and hit adaptive.
Picture 3: I extruded the component
Picture 4: I placed the constranint
Picture 5: I set up the relationship of the adaptivity between the other side
I hope you understand this.
Thank you
Edited by
Discussion_Admin
2 REPLIES 2
BarryZA
in reply to: pajamas4
I tend to go for multi-body solids for stuff like this. Don't know if it's the best but it works.
If you modelled up a part as a multi-body solid and set a view rep for the tube and then placed that view rep on a drawing sheet, those 2 files would give you a nice "adaptive" template.
You could also use the built-in make parts option to push out (derive) the 2 solids into induvidual part files and then into an assembly. So you would have your assembly driven by the original multi-body part.
So take my part, change the overall length and the internal solid will follow.
pajamas4
in reply to: BarryZA
Hello
Can you give me the oldest verson of the file you send me.  The one you send me I couldn't open.  I'm using Inventor 2012.
Thank you
