Good morning everyone
I have a major assembly, of a truck water spray tanker, with all the manufactured parts and sub assemblies.
I now want to add in the buy outs that are not drawn, ie the electrical items, the pneumatic items, the hydraulic items.
I would like to have each as a blank subassembly with a BOM, that I can insert into the master assembly, so it will appear
as a complete list of parts when I export to excel,from that master assembly, parts only mode.
I am guessing it must be possible.
We are using Inventor 2013, we don't use Vault.
My 2 questions are
1. Is it possible
2. How does everybody else add in these parts to their final Assembly BOM.
We are wanting to use this final assembly BOM, as a picking/ordering list for each project, by exporting it to excel, and giving it to the relevant people.
Michael Kovacik
Design Office
Alutip, (Aluminium Tipper/Trailers/Tankers/Dropside Bodies)
+27 73 419 0564
Pretoria, South Africa
Hello Alutip,
What you could do is create an assembly and call it Bought outs.
then 'create in place Componets' check the 'Virtual Component' and call the part Glue or what ever.
Keep adding the parts as required then insert into top level assembly.
The only thing that I am concerned about is these parts would need to be added at top level in order to appear in the BOM unless you do a parts only BOM but that would show every single part in every assembly.
if you do that you could change the BOM structure of the part to 'Purchased' so that when you export to Exel you can sort the data by BOM Structure field.
The way I do it is on the sub-assembly that contains the normal and Bought out items I drop the Virtual parts.
That way they are on that level and are ordered on that sub assembly.
Create a bom and they will all appear but only on an assembly by assembly level.
It all depend on where you want the bought outs to appear.
I hope that helps
Regards
Warren.
2013 Product Design Suite Ultimate 64-bit
2012 Product Design Suite Ultimate 64-bit
2011 Product Design Suite Ultimate 64-bit
All running at the same time 🙂
Have you tried Curtis's code for adding virtual components from excel? He has many versions of this code, but I like and use this.
http://inventortrenches.blogspot.co.uk/2013/07/ilogic-add-standard-virtual-parts-from_29.html
That's how I add grease, oil, grout, anchor bolts, etc..... I have even used it to add man hours.
