I'm new to Inventor (started using it today) and I am trying to model a model rocket with three fins. Obviously I made a work plane on the YZ plane to sketch the first fin and extrude it. However, from above, the fins should be rotated 120 degrees from each other so they are evenly spaced around the fuselage. Essentially, I need a way to create two additional vertical planes that are rotated about the Y axis.
Thank you for any ideas.
Edited by
Discussion_Admin
Solved by JDMather. Go to Solution.
I don't want to sound rude my friend but that new of a question may never be answered you need to do the tutorials and then if you don't understand you can come here and ask. But if you are asking something that simple to learn you will be in here asking to many newbie questions and get frustrated that no one will answer you...
Look into circular Patterns and do the tutorials we are not teachers but helpers....
Attach your ipt file here and someone will teach you how to do a Circular Feature Pattern.
looks like you guys pi$$ed him off..
It is true that this community is not specifically focused on training but more on troubleshooting, but to be fair this is not explicitly mentioned anywhere. You pointed out you were a beginner so you set expectations appropriately. I encourage you to re-edit your original post with your question.
I don't personally know Inventor functionality, but based on the comments, you might want to review this video on the Autodesk Wikihelp site:
If that does not help, JD Mather has kindly offered to help you!
If you read my 1st post I did tell him how to.. told him to look into circular patterns and go though the tutorials..
I just was not going to do it for him like JD he will not learn how to if you do it for him if he is this new.. He needs to watch the video this way he understand how to.
jletcher,
I think the tone of your reply may have been a bit off-putting... though I agree your heart was in the right place. A better approach may have been to welcome the newcomer, show him this one technique as a "freebie"... then gently suggest the tutorial videos and such. It's that whole flies with honey vs. vinegar thingie.
Just my opinion, I know you've helped your share of folks on these forums.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I get the general gist of what has been said in this thread. I agree that this forum is meant for trouble shooting or for the random non-obvious question. I also understand that words can be misconstrude into meanings that were never intended. I personally like to use the ( ) symbols so that feelings are misread.
With that said I hope that the originator of this thread is not so turned off that he never returns. One thing I have learned about forums is there are very different level of users and non of them should be turned away. This forum like others is a valuable resource for gaining knowledge. So please come back and know that we are ultimately out to help you.
I have to say if he is upset with what I said then I feel sorry for him when his boss gets on his case..
Plus I did not tell him not to post or come back. All I said he would get better help if he did the tutorials 1st
many times I tried to help newbie's just to get caught in a never ending explaining every icon every command so to make it easier he needs to do the Tutorials.
Now if he stated I read the tutorials but I still don't understand how this works then I would have gave him a sample and explained...
There ya go! The smileys make all the difference!
I'm just kidding!
Chris Benner
BTW I reached out to Sam and he was able to find the proper tutorial, he's all set.
Thanks guys for offering to help and considering more supportive ways to approach those who may be asking for basic training when they should also turn to tutorials.
