Inventor Forum
Adding work plane to a non-linear surface
8 REPLIES 8
Message 1 of 9
Anthony
2187 Views, 8 Replies
Is there a method to add a work plane to a curved surface ? I need a construction plane adding to a curved surface to allow a sketch to to added to this plane, not sure if this is possible but the problem I have is adding a series of sketches to a curved surface to then extrude-cut for window openings. Thanks
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
8 REPLIES 8
Message 2 of 9
japike
in reply to: Anthony
You can add a workplane tangent to a surface. Is that what you are looking for? Can you post a part? What version of Inventor?
Peace,
Jeff
Inventor 2022
Message 3 of 9
JDMather
Or add construction sketch line or other locating geometry.  There are at least half a dozen ways depending on your design intent.
As suggested - attach your file (or at least a picture) here.
Message 4 of 9
Anthony
in reply to: japike
Hello, unfortunately posting model data is restricted however I can post a screen dump. What I am looking for is a little more complicated that adding a work plane tangent to a surface. I have a dome structure with a curved outside wall to which I need to add window openings - I was looking for a way adding these. I finally figured out a way to do it (it may not be the best method though). See below :
 - Offset work plane from axis
 - Emboss sketch to curved surface with engrave from face and wrap to face selected to wall thinness
 - Create circular pattern of embossed surface
This seems to work OK for me but if there is a better method I would be glad to learn it.
Message 5 of 9
JDMather
I other words - to the cylindrical face, correct?  (not the hemispherical face, in either case it is easy)
In fact, from what I can see - no workplane (other than the origin planes which should be used) is needed.
Message 6 of 9
Anthony
in reply to: JDMather
Yes my apologies for not wording it correctly, is the method I describe OK or are there any quicker / easier ways to reach the same result ? Thanks
Message 7 of 9
JDMather
Are the sides of the window openings parallel or would they form a pie shape to the center of the cylinder if extended the thickness to the center?
Message 8 of 9
JDMather
@Anonymous wrote:
... unfortunately posting model data is restricted however I can post a screen dump. ...
Message 9 of 9
Anthony
I am using IV 2013 SP1 BETA 64-bit.
Could you possibly illustrate on the screen shot what you describe in your previous post with regard to the window edges ? I do not think these would form the pie shape you describe if the thickness is extended through to the central cylinder.
