Inventor Forum
adding welds to pipe
9 REPLIES 9
Message 1 of 10
842 Views, 9 Replies
Are there any cosmetic fillet welds available to add to the pipe where pipe joins pipe and flanges onto the pipes
Can this part be done with a Weld Assembly.I haven`t use welds before?
I use AI 2014
Cheers
Andy
9 REPLIES 9
Message 2 of 10
salariua
Yes to both.
If you do it as chamfer in the part level you might need to play with the scale of the appearance image.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 10
in reply to: salariua
Hi Adrian
Thanks heaps.That looks good
Would you also have how it would look in a Weld Assembly . Weld where pipes join as well as the flanges- Inventor 2013 or 2014?
Thanks again
Andy
Message 4 of 10
salariua
I only have inventor 2015 here but can't imagine it would look massively different. The bottom image is from welding environment.
Adrian S.
blog.ads-sol.com
Message 5 of 10
OK thanks
I have added Welds to the Flanges.How do i add Weld the where boths pipes join?
Message 6 of 10
salariua
It's not playing ball for me, you could add it as chamfer in preparation.
Adrian S.
blog.ads-sol.com
Message 7 of 10
Is it possible to add a Weld where the 2 pipes join.
I thought Weld Assembly was easy as i have never used before but was able to add Welds to the Flanges first time.
Any further assistance appreciated
Andy
Message 8 of 10
salariua
Well the thing is we're not quite simulating reality. Normally you wouldn't have sharp corners on that pipe, you would chamfer the vertical one. A real simulation would be a swept around that intersection but I believe it's not worth doing just for an image, that's why I suggested to use chamfer with different appearance.
Adrian S.
blog.ads-sol.com
Message 9 of 10
Thanks....that works well
Message 10 of 10
salariua
this is what a quick sweep and weld fill looks like.
Adrian S.
blog.ads-sol.com
