Inventor Forum
Adding "document settings" to "quick access toolbar" causes inventor to crash
10 REPLIES 10
Message 1 of 11
998 Views, 10 Replies
When I add "Document Settings" to the quick acess toobar it causes Inventor to Crash when I close the active .ipt, idw, etc.
Anyone else having this problem?
10 REPLIES 10
Message 2 of 11
innovatenate
Hi there! I just wanted to let you know that development is aware of this issue and is looking at it.
Kind Regards,
Nathan Chandler
Principal Specialist
Message 3 of 11
in reply to: innovatenate
That is great news. Thank you
[cid:image001.jpg@01CE66AC.6EA57BB0]
Message 4 of 11
I now have a new computer and now, I can not add the measure command to the quick access toolbar. The option to do so is greyed out.
Message 5 of 11
Kind Regards,
Has there been a solution for this yet?
Message 6 of 11
blair
Not really the answer, but look at a 3D motion controller such as SpacePilot Pro or other 3dConnexion devices. You can map pretty much any command to buttons on the device.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 7 of 11
in reply to: blair
I do have a 3Dconnexion device and already have my buttons mapped. Thank you for the suggestion
Message 8 of 11
innovatenate
I just tested this in Inventor 2014 Service Pack 1. I was able to add the Document Settings to the Quick Access Toolbar (QAT) and I was able to successfully invoke the command. The issue appears to be addressed in the latest versions.
I hope this helps. Let me know if you have any further questions.
Nathan Chandler
Message 9 of 11
Try adding undo check out to the Quick Access Toolbar (QAT). Doing so crashes Inventor on part close,  Inventor 2014 Service Pack 1 - Update 1 & 2
Message 10 of 11
I too can add it. The problem arises when the .ipt is closed. Doing so will crash the Inventor session.
Message 11 of 11
joakim.hjartstam
I have this problem as well but with different commands.
When I ad "Check in", Check out" and "Undo Checkout" Inventor crashes when i switch to another component.
Inventor and Vault have the latest SP and hotfixes.
Any idea when this can be fixed?
best regards
Joakim
