When I add "Document Settings" to the quick acess toobar it causes Inventor to Crash when I close the active .ipt, idw, etc.
Anyone else having this problem?
Solved by innovatenate. Go to Solution.
Hi there! I just wanted to let you know that development is aware of this issue and is looking at it.
Kind Regards,
@innovatenate wrote:Hi there! I just wanted to let you know that development is aware of this issue and is looking at it.
Kind Regards,
Has there been a solution for this yet?
I just tested this in Inventor 2014 Service Pack 1. I was able to add the Document Settings to the Quick Access Toolbar (QAT) and I was able to successfully invoke the command. The issue appears to be addressed in the latest versions.
I hope this helps. Let me know if you have any further questions.
@innovatenate wrote:I just tested this in Inventor 2014 Service Pack 1. I was able to add the Document Settings to the Quick Access Toolbar (QAT) and I was able to successfully invoke the command. The issue appears to be addressed in the latest versions.
Try adding undo check out to the Quick Access Toolbar (QAT). Doing so crashes Inventor on part close, Inventor 2014 Service Pack 1 - Update 1 & 2
I have this problem as well but with different commands.
When I ad "Check in", Check out" and "Undo Checkout" Inventor crashes when i switch to another component.
Inventor and Vault have the latest SP and hotfixes.
Any idea when this can be fixed?
best regards
Joakim
