Inventor General Discussion
gdragos
Message 1 of 4 (244 Views)
Adding Physical Properties to STP Files
244 Views, 3 Replies
05-10-2012 06:18 AM
I'm trying to add some material properties to a STP or IGES file I've received from a customer (in Inventor 2011). Is there any way to add a density for example, so I can obtain the mass of the model? I've tried doing it through the iProperties menu but it's not giving me a mass.
Any ideas/
*Expert Elite*
mcgyvr
Message 2 of 4 (239 Views)
Re: Adding Physical Properties to STP Files
05-10-2012 07:44 AM in reply to: gdragos
and are these imported parts composed of only surfaces..hint hint..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
gdragos
Message 3 of 4 (235 Views)
05-10-2012 07:46 AM in reply to: mcgyvr
Yes, they are imported, surfaces only. Therein is my question: any quick way to convert these surfaces so I can assign material properties?
*Expert Elite*
JDMather
Message 4 of 4 (224 Views)
05-10-2012 09:27 AM in reply to: gdragos
Yes,
If
the geometry is good - use the Repair or Construction Environment to stitch to a solid.
If it is really good, there might be a set of settings on Options to do this automatically on opening.
if the geometry isn't particularly good you still might be able to repair and stitch.
Attach your original files here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Announcements
Need installation help?
