Inventor General Discussion
New Member
vasily_gorbounov
Message 1 of 2 (144 Views)
adding physical boundaries in assemblies
144 Views, 1 Replies
04-27-2012 10:00 AM
How do I set a constraint where 2 parts are attached to each other but do not phase through. For example if I have a door in a door frame, how do I add a constraint where the door can swing on it's hinges but get stopped by the door frame.
Either by using constraint limits or via contact solver... I'd use constraint limits..
mcgyvr
Message 2 of 2 (137 Views)
Re: adding physical boundaries in assemblies
04-27-2012 10:35 AM in reply to: vasily_gorbounov
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
