Are these holes to be in a pattern of some sort?! How big are these holes you require?
I placed the 1st hole and pattern but how do i add holes all around the ball?
I guess i would just create the first hole for next level and pattern like the first set of holes and work my way down
What is the best way to het the holes at the correct angle?
Cheers
TB
In your intial problem description you stated random.
Now you post file with pattern.
What is your true design intent?
If Pattern
will the circular number of holes increase as the pattern moved "down" the sphere?
Didn't this same problem come up here a year or so ago?
