Solved by jonnyrotten. Go to Solution.
That is exaclty what I am after! How did you do it? I can't open the part file as it must be Inventor 2011 and i'm running 2010.
Thanks a lot.
Jonny
this is done in the part environment, not sure how easy it would be to put in the assembly environment. basically create a driven dimension of the value you are wanting to show, then in the same sketch create some text and insert that parameter, (see jpeg) draw some arrows and extrude the arrows and text a minimal amount.
I generally use skeleton modelling techniques which would be easy to drop that part into the assembly but you may want to try adaptive parts or deriving an assembly into a part, (careful not to get cyclic dependencies though)
good luck
hi
i create an assembly. with 3 part
hi
i just turn on Preview:No render in output tab of render animation dialog box
