Inventor General Discussion
Member
martijnvremmerden
Message 1 of 7 (183 Views)
Accepted Solution
adding depth in a picture
183 Views, 6 Replies
02-11-2014 10:07 PM
I'm a little stuck using Autodesk, I really want to have my logo engraved into a custom build project...
but the only thing I Know so far is how to add a image file, and how to engrave text.
is it possible to engrave a imagefile into a solid body (like text)
cya
Welkom op het forum!
It's not possible to emboss an image file, you can only use those as decall.
Your logo doesn't seem too hard to trace, but you could also try using vector software (like illustrator, or the free Inkscape.) to do the tracing for you and saving the file as dwg/dxf.
Hope that helps.
Active Contributor
raveruben
Message 2 of 7 (174 Views)
Re: adding depth in a picture
02-11-2014 10:46 PM in reply to: martijnvremmerden
im not sure if this is posible, can u post a photo of your logo?
is it hard to re-draw it in inventor so you can extrude it?
greets from holland!
Member
martijnvremmerden
Message 3 of 7 (171 Views)
02-11-2014 10:49 PM in reply to: raveruben
Njiua
this is the logo
Active Contributor
raveruben
Message 4 of 7 (164 Views)
02-11-2014 10:58 PM in reply to: martijnvremmerden
its not the most easy logo to draw in autocad or inventor, but i think there's no other way to get a closed sketch reddy for a extrusion.
so maybe someone els knows a way?
otherwise goodluck with drawing it!
*Expert Elite*
-niels-
Message 5 of 7 (164 Views)
02-11-2014 11:05 PM in reply to: martijnvremmerden
Hope that helps.
Using IV2014 Pro SP2 - upd.1, Win7-64bit
*Expert Elite*
-niels-
Message 6 of 7 (154 Views)
02-12-2014 12:03 AM in reply to: -niels-
I couldn't resist, took some cleanup to get it to work properly and the geometry will not be exactly the same but i hope you can use it.
Member
martijnvremmerden
Message 7 of 7 (136 Views)
02-12-2014 01:11 AM in reply to: -niels-
it worked, used inkscape to redraw it. It was easier than expected so I redisigned it for a bit
Post to the Community
New Post
Need installation help?
