Inventor General Discussion
889 Kudos
Post 1 of 9
Adding corner round crashes Inventor
328 Views, 8 Replies
09-20-2012 09:44 AM
1) Save your files.
2) Open attached ipt.
3) Add four .060 corner rounds to all four corners.
4) Inventor crashes.
Edit: By crash I mean it gets stuck thinking about something and has to have it's process killed. Yes, I let it run to see if it would complete it; I let it go for my 45 minute lunch break.
Mike (not Matt) Rattray
This is reproducible, and has been logged as 1473550 in our tracking system. Anyway there is one workaround that you could add the corner round before unfold/refold, and it works fine. If there is any concern or detail you would like to share, please send me email @ river-yijiang.cai@autodesk.com.
889 Kudos
Post 2 of 9
Re: Adding corner round crashes Inventor
09-20-2012 10:27 AM in reply to: mrattray
What the f*** is this?
1,270 Kudos
Post 3 of 9
09-20-2012 10:42 AM in reply to: mrattray
Solar panels floating in space??  :smileylol:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
2,120 Kudos
Post 4 of 9
09-20-2012 11:58 AM in reply to: mrattray
Try this one.
Looks like you found a bug in Unfold/Refold.  Or maybe a combination of Punch with Unfold/Refold.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Pro
284 Kudos
Post 5 of 9
09-20-2012 12:16 PM in reply to: mrattray
Weird.  Same result here adding the corner rounds (but, I don't see the "solar panel").  But if I pull the End of Folded marker up to just under the Contour Flange feature and add corner rounds there, then pull down again, there appears to be no problem.
889 Kudos
Post 6 of 9
09-20-2012 12:52 PM in reply to: sbixler
889 Kudos
Post 7 of 9
09-20-2012 12:54 PM in reply to: mrattray
Employee
38 Kudos
Post 8 of 9
09-20-2012 10:29 PM in reply to: mrattray
River Cai
Inventor Quality Assurance Team
889 Kudos
Post 9 of 9
09-24-2012 11:59 AM in reply to: Yijiang.Cai
I have a nother part exhibiting the same behaviour. I don't think it matters, but these parts are both parents of derived parts created through an assembly mirror operation.
