I have been struggling with this:
It is an existing sheet metal part. I just need to add a simple contour flange on one of the edges. I made a sketch, drew my profile, exit sketch, contour flange, highlighted the profile, the "OK" bottun is greyed out. Why??
Sammy
Inventor Standard 2014
Dell Precision T3610,
Installed Memory: 16 GB,
System Type: 64-bit
Solved by Curtis_Waguespack. Go to Solution.
Hi samuel777,
From the screen shot it looks like you simply need to select the edge of the part along which the contour flange will run, then the OK button should become active.
I hope this helps.
Curtis
That was too fast 🙂
Thank you for the prompt reply
Appreciate the help
Sammy
