Inventor Forum
adding color
8 REPLIES 8
Message 1 of 9
847 Views, 8 Replies
adding color
I have some shapes in which i want to add solid color to sections.I cannot find anywhere to accomplish this effect.Can this be done in Inventor 2013..it will be a 2D view
Please view the attached 2013 file...can this be done
Rich
8 REPLIES 8
Message 2 of 9
JDMather
If it is 2D - why aren't you creating the sketch in idw or dwg?
http://forums.autodesk.com/t5/AutoCAD-2013/symbols/td-p/3649346
Message 3 of 9
in reply to: JDMather
I use Inventor much more then Autocad (new) so if possible would rat5her do in Inventor
Rich
Message 4 of 9
JDMather
If it is 2D - why aren't you creating the sketch in Inventor idw or Inventor dwg?
Sketched Symbols might be the way to go.
Message 5 of 9
Thanks..
Yes you are correct....can the title block be removed from the bottom right hand corner
Rich
Message 6 of 9
JDMather
Yes.
Right mouse button in browser.
Message 7 of 9
JD Thank you
1 final question....can the shapes be filled in with solid colors
Rich
Message 8 of 9
JDMather
Yes.
Hatch/Color Fill.   (Fill/Hatch Region)
....and why do I doubt this is the final question?   Smiley Surprised
Message 9 of 9
It is as i also just found it
Rich
