Inventor Forum
Adding Color to Content Center Parts
3 REPLIES 3
ThomasSwanson
835 Views, 3 Replies
I am trying to add color to my content center parts.  For example I want all M10 hex head bolts to be red and all M12 hex heads to be blue.
I have My library configured in content center and I take from the "Inventor ANSI" catalog the "Heavy Hex Bolt -Metric" and right click and copy to my library. I switch the sort back to merged view and right click  on the "Heavy Hex Bolt - Metric" and select family table. I scroll to the end of the table and insert a new column and set the "Column Name" To "Color" and set the "Column Caption" to "Color" , "Map to Inventor Property:" is set to "Member.Color"
Now going back to the family table I have to enter simple color names like, Red, Green, or Black, I cannot enter names like Water Bubbles, Particle Board, or any of the Inventor Apperance names. If you do you will recive an error on placing the part stating " Unable to create componet"
Futhermore when you click on the Material Column you get a drop down of all the different materials.
Why do I not get a similiar drop down for the colors/apperances?
What is the list of working colors names?
3 REPLIES 3
cbenner
in reply to: ThomasSwanson
mpatchus
I haven't tried this so I'm not 100% positive that it would work, and it would depend on how many different colors you desire.  Too many variation would be prohibitive.
That being said, why not create a material style for each color that you wish to utilize.  Something along the lines of STEEL_BLUE, STEEL_RED, STEEL_GREEN, etc.   Since the material can be access via a pull down in the CC Editor, you could then control the appearance of selected items by applying the appropriate material style.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
lesmfunk
This statement appears to be incorrect. I can enter Water Bubbles or Particle Board and it does update to the new appearance (IV2014). Don't forget to refresh the file.
I know it is an old post, but it steered me in the wrong direction, so I don't want that to happen to anyone else.
