Is it possible to add a Appearance tab to a Ipart table? I am cataloging a set of parts and one part is made with steel but in Gloss - Black and Matte - Black and i'd like to differentiate the 2 without haveing to make 2 seperate Ipart files.
Solved by jbellric. Go to Solution.
Nevermind, I was shown how to add a custom proprty to my Ipart table and designate it as the appearance column. For those who looked like i did, go to other, click in the Right window and add a new Propoerty, then right click on it in the table and select the appearance line to designate as the appearance line.
One easy way to do this is using "Edit Member Scope"
In this mode, your design change will be captured in the iPart table.
(Please refer the attached video capture in the zip).
Hope this helps,
-Sami Harada
Inventor Framework QA
