Hi, I have just managed to create my own title block and have an area within for material. I always use the iProperties to populate the titleblock but there isnt a field for material? Is there a way to add a field so it does what i need?
I have a screenshot to try and help explain what I mean (maybe!)
Is that screen shot from the drawing iproperties? Material would most likely be pulled from the part itself.
To use this on your titleblock you would set the field to Properties - Model and then Material. It will pick up that value from whatever model you put into that drawing.
Hope this helps.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Yeah thats the screenshot from the drawing iProperties. Is the one you posted from the part iProperties? Ill give it a go. Would it also work if I give the part a material from the top right selection dropdown box?
Thanks for your help so far!
Pete
Hey Peter,
I too use the material in the title block.
I named all my sheet metal rules to specify material and gauge/thickness, so I needed a rule in my drawing template to use this info. So what I did (with the help of others) was create a custom iProperty called MaterialInfo. I have a rule in each sheet metal and part template, so that once I create the part, assign the material parameters and save, the rule automatically creates this custom iProterty. this can be edited manually also in the custom tab of the iProperties menu. I then make sure my drawing template has this in the titleblock so that once a base view is dropped the iproperty is populated.
here is the rule imbedded into the part files:
Dim oDoc = ThisApplication.ActiveDocument If oDoc.DocumentType = kPartDocumentObject Then 'Confirm part If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'Confirm Sheetmetal Try: Stock = iProperties.Value("Custom", "SheetMetalRule") Catch: MsgBox("SheetMetalRule iProperty Doest not exist") End Try Else 'Confirm Standard Stock = iProperties.Material End If Try: iProperties.Value("Custom", "MaterialInfo") = Stock Catch: MsgBox("MaterialInfo iProperty Doest not exist") End Try Else MsgBox("File is not a part") End If
Good Luck!
Thanks to ChrisB I have got it working.
Sean, i'm not sure where I would paste that code but it seems there is more than one way to accomplish the task. I work in the education sector so would really have the need for a huge range of material properties, but from a personal point of view, thanks for your help - im sure it will come in handy one day!
Pete
