Inventor General Discussion
SimonBritton
Message 1 of 3 (241 Views)
Adding an image to a dwg
241 Views, 2 Replies
08-18-2011 01:31 AM
Hi
Is it possible to add an image (bitmap, pdf or jpeg) to a drawing
Simon
Hi Simon,
Please, try the following.
In the dwg file, menu Manage > Insert > Insert Object.
In the Insert Object dialog, select the option “Create from File”, Browse to the file, open it and then click OK in the Insert Object dialog.
Position the file in the desired location in the drawing.
I hope this can be helpful.
If not, please, provide more details about what you want to do.
Thanks and regards,
Alessandro
Product Support
alessandro.gasso
Message 2 of 3 (237 Views)
Re: Adding an image to a dwg
08-18-2011 03:12 AM in reply to: SimonBritton
Hi Simon,
Thanks and regards,
Alessandro
Alessandro Gasso
Product Support Technical Lead
MFG - Inventor
SimonBritton
Message 3 of 3 (230 Views)
08-18-2011 04:03 AM in reply to: alessandro.gasso
Perfect, thanks very much
Regards
Simon
