Inventor Forum
Adding an image to a dwg
2 REPLIES 2
SimonBritton
442 Views, 2 Replies
Hi
Is it possible to add an image (bitmap, pdf or jpeg) to a drawing
Simon
2 REPLIES 2
Hi Simon,
Please, try the following.
In the dwg file, menu Manage > Insert > Insert Object.
In the Insert Object dialog, select the option “Create from File”, Browse to the file, open it and then click OK in the Insert Object dialog.
Position the file in the desired location in the drawing.
I hope this can be helpful.
If not, please, provide more details about what you want to do.
Thanks and regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Perfect, thanks very much
Regards
Simon
