I am trying to add a slant to a extrusion. I wont be able to use the split feature because I cannot add a sketch to the side of the disk.
Your desired result is not quite clear. Do you mean to taper the extrusion like a cone or pyramid, or have the sketch extrude in a non-perpendicular direction like a skewed stack of coins?
Notice all of the i in circles.
Looks like you have a lot of other problems that I would take care of first.
Can you attach the *.ipt file here?
