Hi there,
I'm havine the same problem as described in this thread:
http://forums.autodesk.com/t5/Inventor-Customization/Sheet-Size-iLogic-Problem/td-p/3736628
Basically I've made all my borders using the define zone border wizard as it was the quickest and easiest way to do them. When adding them with iLogic they come in the zone numbers, both horizontal and vertical, set to 0.
I do not want to use the solution in the above thread as my template will be used in UK, China and Brazil and I'm worried the language settings will cause errors.
Is there a way I can save \ convert my zone borders to custom borders? I think this would solve all my problems, I really don't want to draw them again. Or has this been fixed in a new version? I'm running 2013.
thanks,
John
I created my own borders that insert based on sheet size
'A4 Border Portrait LandscapeIf ActiveSheet.Size="A4" And ActiveSheet.Width="210" And ActiveSheet.Height="297"Then ActiveSheet.Border="MSub-BORDER_A4P" ElseIf ActiveSheet.Size="A4" And ActiveSheet.Width="297" And ActiveSheet.Height="210"Then ActiveSheet.Border="MSub-BORDER_A4L" 'A3 Border Portrait LandscapeElseIf ActiveSheet.Size="A3" And ActiveSheet.Width="297" And ActiveSheet.Height="420"Then ActiveSheet.Border="MSub-BORDER_A3P" ElseIf ActiveSheet.Size="A3" And ActiveSheet.Width="420" And ActiveSheet.Height="297"Then ActiveSheet.Border="MSub-BORDER_A3L" 'A2 Border Portrait LandscapeElseIf ActiveSheet.Size="A2" And ActiveSheet.Width="420" And ActiveSheet.Height="594"Then ActiveSheet.Border="MSub-BORDER_A2P" ElseIf ActiveSheet.Size="A2" And ActiveSheet.Width="594" And ActiveSheet.Height="420"Then ActiveSheet.Border="MSub-BORDER_A2L" 'A1 BorderElseIf ActiveSheet.Size="A1" Then ActiveSheet.Border="MSub-BORDER_A1L" 'A0 BorderElseIf ActiveSheet.Size="A0" Then ActiveSheet.Border="MSub-BORDER_A0L" End If
formatted correctly
'A1 Border
'A0 Border
End If
