Inventor Forum
Add Tolerance to Holes that are created by iFeatures?
1 REPLY 1
tdswanson
490 Views, 1 Reply
Hey everone:
I've got an interesting question.  I've got an iFeature created that's very handy.  It's basically a reamed hole with a counterbore for a purchased locating pin.
Here's the rub:  Is there a way to specify a tolerance to that hole that will come through the iFeature?  As in, I can draw the hole with a diameter of 0.501" within the defintion of the iFeature.  That's easy.  However, when I do a print, I'd like to be able to just snap a leader to it that will have the "Use Part Tolerance" box checked and will refect the correct tolerance.
As an aside, one of the reasons I want to do this is because I use Hole Tables a lot.  In a hole table, I can manually go in and change the callout for the hole to show the correct tolerance, but in order to keep the grouping together, I have to do EVERY hole individually.
Is there an easier way?
Thanks!
1 REPLY 1
tdswanson
in reply to: tdswanson
So no one's done this then?
