Hello people,
I have recently started playing with the new materials and appearances browsers - what a nightmare.
So I created a custom library as described in the "Materials and Appearances" whitepaper from Autodesk.
Then:
Bottom left corner of material browser > create new material
> edit material: change its name, density etc
Why can I not add it to the new custom library - from document materials?
I tried to drag and drop - no success.
I tried to right click > add to > xxx material library - no success.
It does however let me drag and drop to the "favorites".
Any help, further procedures or insight greatly appreciated.
Regards.
Welcome to Materials & Appearances! You have to just keep trying. I can't tell you what sequence of saves, updates, purges, etc will finally get the job done, but something will work. When you have the material the way you want, purge all other materials from the document, save and exit, then start up again. Make sure the library is added to your project. Then try to copy it to the library. If that doesn't work, try the Save Styles tool (works with M&A libraries, too).
Yes, we all want our Material & Color styles back.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
This is a good document
Thanks folks.
That attached document is the "whitepaper" I was referring to. A good document but more centred around migration rather than just straight out creating a material and/or appearance. So not a great document for me. There really needs to be more from Autodesk on this in my opinion - considering it's a completely new tool.
I finally got my document material into my library - by doing the same thing I had been. Also a document appearance. Then got an ipart I recently created over to it.
Very clunky indeed.
I will no doubt have further queries in the near future.
Regards.
I agree.
Use tko be able to swich units on the fly while creating custom materila properties.
I cannot find any information regarding how to create a new material style.
I’d like to create a carbon steel AISI-ASTM CORTEN A style having the following Mechanical Properties; @ 25°C
Density 7.85 x 1000 kg/m3,
Poisson’s Ratio 0.28,
Elastic Modulus 200 GPa,
Tensile Strength 1158 MPa,
Yield Strength 1034 MPa,
Elongation 15%,
Reduction in Area 53%,
Hardness 335HB, and
Physical Properties;
Thermal Conductivity 42.7W/m-K @100°C,
Specific Heat 477 J/kg.K,
Thermal Expansion 17e-6/K
Have you tried the WikiHelp? Try here: WikiHelp: Materials.
Sam B
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
Haven't tried it yet, but this looks clearer and more logical, albeit long-winded!
http://www.trainingtutorial.com/TAT38_Custom_Autodesk_Inventor_2013_Material_Library.htm
+1 on that PaulB108
Keep it simple, add functionality/options but keep what is working just as it is.
Regards
