Inventor Forum
Add Item to Multi-Value-List of a Userparameter (IV2012 API)
4 REPLIES 4
abrink100
654 Views, 4 Replies
IV2012 API with VB:
how can i add an item to a Multi-Value-List of an axisting UserParameter in Inventor2012 (Accessing API with Visual Basic) ?
My idea is for example:
uParams.Item(i).ExpressionList.AddItem(As String)
The problem is, that such a function "AddItem" doesn't exist.
Can anybody help me ?
Thank You very much.
4 REPLIES 4
jddickson
in reply to: abrink100
Here is an example I use for some of my stuff. I hope this helps. This will also add the parameter to the part if it’s not in there.
Imports  Inventor.UnitsTypeEnum
Dim oPartDoc As Document
oPartDoc = ThisDoc.Document
If oPartDoc.DocumentType = kPartDocumentObject Then
    Dim oPartCompDef As PartComponentDefinition
        oPartCompDef = oPartDoc.ComponentDefinition
Dim oParams As Parameters
        oParams=oPartCompDef.Parameters
        Dim oUserParams As UserParameters
        oUserParams=oParams.UserParameters
        Dim oAwesomeParameter As Parameter
                    Try
            otester = oUserParams.Item("PK_Ship_Loose")
            Catch
oInsulationType=oUserParams.AddByValue("PK_Ship_Loose", "No", kTextUnits)
MultiValue.SetList("PK_Ship_Loose", "Yes", "No")
            End Try
Parameter.Param("PK_Ship_Loose").ExposedAsProperty = False
Parameter.Param("PK_Ship_Loose").IsKey = False
abrink100
in reply to: jddickson
Hello jddickson,
in this example you only create a Userparameter if it doesn't exist and prepare a Multi-Value-List.
What I need, is to add an Item to an allready existing parameter and an allready existing Multi-Value-List with the "text" unit and with content.
For eample i have a Parameter called: PARAM1 and three values in the Multi-Value-List: Text1, Text2, Text3.
Now a need to add one Item (value), taht for example could be the text: Text4.
Can you tell me how ?
jddickson
There is probably an easier way to do it but you could delete the parameter first using an “IF Statement”.  Then you could use the code I sent you before adding anything new to the Mulit-Value-List. I know there has to be a better way but I know this should do everything you need.  I taught myself how to do this stuff so my know how is limited. The code below could be used to delete the parameter.
I hope this helps in some way.
Dim param As Parameter
param = oDoc.ComponentDefinition.Parameters.Item("PARAM1")
param.Delete
abrink100
I also told myself. You don't need to delete the parameter to put something new into the list. You only have to clear the Expressionlist and assign a new one.
