Inventor General Discussion
Active Member
Rfechner
Message 1 of 18 (6,501 Views)
Add-in Thread Modeler Issues
6501 Views, 17 Replies
01-23-2013 06:49 AM
I am having a terrible time getting the thread modeler to work correctly for an M16x 1.5 thread. I have tried multiple approaches to get the correct thread dimensions output.
These are the steps I take:
1) Create hole (I've used both  major and minor thread diameters,16mm and 14.376mm)
2) Apply Inventor threads (M16 x 1.5)
3) Select threads from tree using the Add-in thread modeler "Controller"
4) Analyze dimensions finding both cases yield the wrong dimensions.
I have attached a picture of my results. This add-in would be very useful and a great time saver if it would work correctly. Any thoughts?
Thank you,
Ryan
From the Quick Start.doc
British Standard Whitworth
Valued Mentor
Mason-Paul
Message 2 of 18 (6,477 Views)
Re: Add-in Thread Modeler Issues
01-23-2013 07:32 AM in reply to: Rfechner
Your going about it the wrong way.
Not necessary in this order
you need to do is select the hole location method from the drop down list  follow, then select the thread hole option, set you thread size and type from the table and click APPLY
SEE ATTACHED.
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
JDMather
Message 3 of 18 (6,471 Views)
01-23-2013 07:35 AM in reply to: Rfechner
Is there a reason you need modeled threads (like maybe for RP) rather than simplified cosmetic representation?
Can you attach the resulting ipt file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Mentor
Mason-Paul
Message 4 of 18 (6,452 Views)
01-23-2013 08:01 AM in reply to: Rfechner
IF you are actually modeling/cutting the treads you might find the two attached files helpful.
1) is the mentored that I use for modeling/cutting a square thread but you can adapt that but cahnge the profile of the tread
2) A copy of the metric threads page from ZEUS data charts this give the tapping, clearance, thread pitch etc for the most commonly used threads, this is a UK publication so there will NO DOUBT be some slight differences to some other country's calculations for the same threads.
Inventor 2014 Pro
64bit Windows 7 Pro
Active Member
Rfechner
Message 5 of 18 (6,421 Views)
01-23-2013 09:01 AM in reply to: JDMather
Hi JDMather,
The File is too large to attach to the forum, Let's try this dropbox link: Test.ipt
I would like to clarify, I did not create the hole using the "hole" feature, I made a sketch with the circles and extruded the shape. However, I did try using the hole method with the same results.
I am cutting the threads vs. cosmetic because I need to convert the .ipt to an .iges file to send to our supplier, the threads don't carry over once the file is converted. I want to be sure the part he opens is as intended.
Ryan
p.s. I also will admit I have no formal training with Inventor (which I would love to have), I'm learning as I go and it can be frusterating at times. I have had formal training with Solid Edge and NX, so some things carry over, but there's still a lot I need to learn.
Active Member
Rfechner
Message 6 of 18 (6,414 Views)
01-23-2013 09:07 AM in reply to: Mason-Paul
Hi Mason-Paul,
I tried creating the hole using your method and still had the same outcome. After using the add-in thread modeler, it resulted with an incorrect sized thread. Also, I am using Inventor 2013, so our menu's are slightly different, I don't believe there is a way to select the thread from the "hole" feature anymore.
Ryan
JDMather
Message 7 of 18 (6,407 Views)
01-23-2013 09:16 AM in reply to: Rfechner
Rfechner wrote:
Hi JDMather,
Find the red End of Part marker at the bottom of the feature tree.
Drag the red EOP to the top of the browser hiding all part features.
Save the file with the EOP in a rolled up state.
In Windows Explorer right click on the filename and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Active Member
Rfechner
Message 8 of 18 (6,403 Views)
IRe: Add-in Thread Modeler Issues
01-23-2013 09:26 AM in reply to: JDMather
I take it the dropbox link did not work? No need to zip the file now, it's very small. Thanks for that useful tip!
JDMather
Message 9 of 18 (6,383 Views)
Re: IRe: Add-in Thread Modeler Issues
01-23-2013 09:51 AM in reply to: Rfechner
I suspect actual cut theads will cause problems with your vendor.
This helix could be big problem with IGES, be sure to set Options to Solid.
I would put tap drill size hole and note thread size.
I have never used this thread add-in, but I would question the specifications.
First of all, I would expect the angle to be 60° rather than 55°.
I don't understand why there are 3 solid bodies.
Where can I download this add-in to experiment?
The more I look at this - it isn't done correctly.
Active Member
Rfechner
Message 10 of 18 (6,381 Views)
01-23-2013 09:54 AM in reply to: JDMather
JD,
You're right, I was expecting the angle to be 60deg as well. Some strange things happening with the add-in.
http://labs.autodesk.com/utilities/thread_modeler/
Glad it's not just me!
