OK I'm a bit confused.
What is the issue?
In the example you posted if I change the base extrusion the sweep changes
as well.
If I delete the sweep and project the face of the extrusion then use this
for the sweep, the sweep also changes with a change to the base extrusion.
I see what you say about not being able to make it adaptive via RMB after
the sweep but I don't think it's necessary in this context. Now had you
been projecting geometry from another part then it would be required.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Laurence Yeandle" wrote in message
news:3B2F22CB6BDB4A2B85823163E6B63FBF@in.WebX.maYIadrTaRb...
> Sorry for the delay Sean,
> I have put a file in CF which is a virtual copy of what I mean, the
> exception is that I was trying to use project cut edges in my original
> instead of project edges like in CF. We know that project cut edges cannot
> be made adaptive.
> The fact remains that although you can it appears make a sweep adaptive
you
> have to make sketch adaptive before the constructing sweep? and once
applied
> can not be undone by RMB whatever? Only by deleting the sweep first!
Unless
> I missed something? Other features you just RMB adaptive or properties.
> Thanks.
> Laurence,
> Power is nothing without Control
> "Sean Dotson" wrote in message
> news:4255247EB878C1004617E0E56AF5BD71@in.WebX.maYIadrTaRb...
> > Laurence,
> > Can you post what you have. It's a bit hard to visualize what you are
> > saying...
> > Sean Dotson, PE
> > news:A42E0263EEF8765AD113AAA8627563FC@in.WebX.maYIadrTaRb...
> > > Hi all,
> > > I thought after modelling a part that I wanted to change the base
> sketch,
> > so
> > > I made some of the features below it adaptive , no problem. Then I got
> to
> > > the sweep and I couldn't RMB adaptive on the feature through
properties,
> > or
> > > make the sketches adaptive either, no option 😞 So I delete the
> sweep
> > > and make the sketch for path adaptive then redo the sweep, aha
adaptive
> > > sweep. No it looks like one but it doesn't behave like one 😞 Am I
> > doing
> > > this wrong or is this feature not capable of adaptivity?
> > > Laurence,
