I'm trying to make what should be a simple assembly other than making one part adaptive. I'm trying to make a roll cover, think window shade. It's just a stand in part so it just only needs the cylinder the cover rolls up on, the stretched out fabric coming off it, and a bar at the end that the fabric is attached too.
I have a picture attached of a side view. I'm stuck making the fabric adaptive between the roll and the end piece. I want to have these three parts in an assembly which I could turn adaptive or flexible in my main assembly. Then the roll would be fixed and the end bar would be constrained to a moving part and the fabric would "roll in and out" as the end bar moves. Thanks for any help.
Well here is the assembly and parts. The fabric piece will probably have to be redrawn or something to make it work.
So, how did this go? I'm working on the exact same thing trying to figure it out now...
Never figured it out. Gave up before wasting too much time, since I'd probably still be trying to make it work nearly 7 years later.
Animate Parameters.
Hi Guys,
I don't believe there is a way to do that. The issue here is that there is no sketch constraint or body feature to allow such deformation. The sketch will have to change from a straight line to a spiral. The body will have to roll accordingly. I don't think Inventor can do it. I am happy to be proven otherwise.
Many thanks!
Some years ago I've been playing with a LEGO Tow Truck and a crane hook animation. See attached video.
The fileset can be found at GrabCad:
https://grabcad.com/library/lego-technic-tow-truck-8462-1
The WMV there shows some other movements. Just now I've seen that the rotation of the drum in the GrabCad fileset probably needs to be inverted; I had to do that for the new video.
Walter Holzwarth
@WHolzwarth amazing work Walter!
Admaiora
I've modified the old models a little, and added linked parameters to make it work in Studio.
Attached is a small video and a P&G in ZIP, if anyone wants to "dissect".
(2020 format)
Attached is a 2020 iLogic version of this, it contains a couple of rules that will allow you to drag the slider to roll/unroll it or click the play button to auto roll/unroll it... the roll diameter calculation is just sort of fudged to look about right and not truly calculated.
Good job, Curtis.
Here's the formula for the diameter:
https://rechneronline.de/rolle/
Walter Holzwarth
