Inventor Forum
Adaptive radius?
10 REPLIES 10
Message 1 of 11
227 Views, 10 Replies
Adaptive radius?
Picture a narrow flat (flexible) part with a hole in the middle and on the ends. In an assembly many are connected together to form a circle. (Think of a stretching toddler's gate across a doorway, but now attached to itself in a circle.) Based on some constraints, the pieces should be able to bend varying amounts, but all together. I've read about holes being adaptable, but I can't figure out how to make this work. Don't be afraid to "dumb it down" a little. Thanks in Advance.
-William
10 REPLIES 10
Message 2 of 11
-William
Hi
I have uploaded a exsample to inventor customer files.
Maybe you can use it.
Brian
Message 3 of 11
Think you missed the IAM out Brian?
Laurence,
Power is nothing without Control
"Brian" wrote in message
news:5A79789F559BD10C18510BC5FD6780F5@in.WebX.maYIadrTaRb...
of
in
> -William
> Hi
> Brian
Message 4 of 11
vuonos
I understood your assembly is kind of a ring made of flat bars, joint together like scissors?
Bending of those flat parts haunted me so much i had to model it. Part have to maintain the length of its neutral axis to bend correctly. I'll post a sketch model of a flat bar that can be bent by dragging one end downwards. If you'll examine the model, you'll find the formulas behind it. It simply calculates the arc length in relation to radius and bend angle.
Now, making this adaptive in context you want may be a head ache and i can't arse myself to do that. You may know that all instances of the same adaptive part are acting alike, so achieving varying bend amounts would require individually named flat bars. I have not tried skeleton modeling technique myself, but i would imagine you could find your solution from there.
Sorry i couldn't help you more,
Tero
Message 5 of 11
Brian,
I'm really sorry to say that I'm using 5.3. It just didn't look like much was going on in that group and I wasn't expecting an example. So, I was unable to open the files. Are you willing to do it R5.3? Thanks and sorrry- William
Message 6 of 11
Tero,
Thanks, but no files were available. Also, I'm R5.3. I probably should have said that or gone to that group. The formulas will probably be over my head. But am anxious to see how you did this. Thanks, William
Message 7 of 11
William
Would it be possible to talk you into changing your posting name? Many of us color code
posts from Autodesk Employees and with Autodesk in your name it makes you look like you
are a Autodesk employee.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"whautodesk" wrote in message news:f19c756.3@WebX.maYIadrTaRb...
> Tero,
Message 8 of 11
I'll ask the same.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kent Keller" wrote in message
news:3F08D2F4DA2EDDC0550F04EC3034EFA8@in.WebX.maYIadrTaRb...
> William
us color code
look like you
> Kent
> Assistant Moderator
> > Tero,
have said that or
anxious to see how
Message 9 of 11
williamart
No problem at all. I thought I was going to be asked for a 'handle' or something. Didn't know that was going to show-up like that. Consider it done. - William
Message 10 of 11
Thanks. It is appreciated. 8^)
Kent
Assistant Moderator
"williamart" wrote in message news:f19c756.7@WebX.maYIadrTaRb...
Message 11 of 11
Probably, I did look for something like that, but did not find it.
Brian
