Inventor Forum
Adaptive Iparts
15 REPLIES 15
Message 1 of 16
A_Harro
533 Views, 15 Replies
Adaptive Iparts
I was hoping that autodesk reads this forum because i really would like to have an adaptive Ipart.
They say it cant be done because it defeats the purpose of having an ipart library where the items do not change in size.
How does one go about having 20 odd sizes of steel angle and the only thing you need adaptive is the length. So i have to make 20 separate files now for each sized angle? This is ridiculous. How have the rest of you guys gone about this?
Cheers 😞 Anne
15 REPLIES 15
Message 2 of 16
in reply to: A_Harro
>So i have
By making 20 different files for each sized
angle.<g>  Makes perfect sense to me.  What if you wanted a hole
in one and not the other?  Now they'd have to be separate files
anyway...
I assume you are using custom iParts?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
an adaptive Ipart.
How does
Cheers 😞 Anne
Message 3 of 16
As Sean commented... you need to create an iPart with the various cross
section dim values listed in a table, with an additional column added
dor the length. Make the Length column a custom input column
(right-click on the length column.
For mre info, go to Seans website at http://www.sdotson.com and download
the tutorials.
Dennis
> Cheers 😞 Anne
Dennis Jeffrey
Autodesk Product Consulting and Training
Center for Design Excellence
http://www.design-excellence.com
260-459-1311 ext 221 or 800-550-6070 ext 221
Message 4 of 16
buff you are 100% correct it is frustrating to have an ipart that has a custom length to it not behave adaptivly. Ive screamed about this one and many other inflexible problems that this software has to offer. The worst part about all this is that Inventor will allow you to set iparts to be adaptive, it makes you wonder?
Message 5 of 16
A_Harro
Hey Sean,
Yes we are using custom iparts. 1 file/dwg that has the information for every size of steel angle (for example). Its great that i can set a custom length and type in the dimension i want, but what if i need to stretch the item 200 mm or something, i have to insert a new part..
Its just a bit frustrating. I guess its back to the ol' 1 drawing per item isnt it 😞
cheers anne;)
Message 6 of 16
iParts are non-adaptive by design, even if you can change the adaptivity
flag, there are no features in the part (proxy file) to adapt. Hoever,
replace component works fine and even retains the constraints.
This most likely will never change in future releases. iParts
essentially create proxy files of dumb solids.
Dennis
Dennis Jeffrey
Message 7 of 16
You don't have to insert a new part.  Open the
part from the assy and expand the table.  RMB on the row you want and
select compute row.  It will allow you to change the custom
parameter.  Then save and return to the assy and update.
Not as nice as adaptivity but you don't have to
insert a new part.
Sean Dotson, PE
Check the Inventor
Hey
Sean,
Its just a bit
 cheers anne;)
Message 8 of 16
No expert on this but the last time I inserted a custom ipart it prompted me for the file location which was typically in the current project. This is not to be confused with an ipart factory which resides in the library! Now, what people want to see is the flexibility for an adaptive extrusion of the original ipart while maintaning control of the end shape of the part in the library.
Message 9 of 16
Yes it does, however it still is linked to the
parent.  You could always delete the iPart information from this part and
make a normal part and then it could become adaptive.
If the part could be adaptive then any aspect could
be adaptive (length, width, height etc..)  Since these parameters are all
controlled by the factory then you have a problem.  Not saying one day this
might be added but I wouldn't hold my breath.
Not arguing with what could or should be.
Just what is...
Sean Dotson, PE
Check the Inventor
No
library.
Message 10 of 16
actually there is a workaround to this but its alot of work getting there. What I do is generate a custom ipart of very small length (0.000000001) and place it in my current project. Now this part refrences back to the original ipart. Now I create another part that is derived off of the ipart in the project folder and create an extrusion from a projected edge of the original ipart and set this extrusion to adaptive. Now when I pull the part into the assembly it can behave adaptivly to the extrusion. It's crude but it does work while mainting ipart shape integrity.
Message 11 of 16
I am probably missing it, but I don't understand why you don't just make a template that
has the part started that you can make adaptive. A while back I posted a snippet of code
that would open a template, save it as a file, close the template and open the new file.
If I remember right it was for IDW's but something similar could be done for IPT's pretty
easily.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"ohunome" wrote in message news:f18a6bc.8@WebX.maYIadrTaRb...
Message 12 of 16
Kent, I agree with your solution.
But in the previous suggestion I don't understand why a new derived part
needs to be created. The extrusion feature could have been added to the
iPart member itself.
Another approach is to use a catalog of iFeatures.
"Kent Keller" wrote in message
news:2A0D567F4741AD1D9E5C90B5778DA6E4@in.WebX.maYIadrTaRb...
template that
snippet of code
the new file.
for IPT's pretty
> easily.
> Kent
> Assistant Moderator
there. What I do is
my current
another part
extrusion from a
Now when I pull
crude but it
Message 13 of 16
good point not sure why i used a derived part.
Message 14 of 16
A_Harro
AHUH!! Ifeatures 🙂 Thank goodness there is something that will do what i want! Now i have a nice little library of sketches for some steel shapes. I insert the ifeature and amazingly, i have an extruded steel shape that is adaptive and a individual file. Excellent.
I think this is the way to go.
Thanks to everyone for their contribution to this issue.
Regards Anne 🙂
Message 15 of 16
If you change the profile of the iFeature does it
propagate down to each part that uses that iFeature?  It wouldn't be a
problem if you aren't going to change the profile.  Would a part file saved
somewhere derived into another part with just the sketch work?  That way if
you need to change the original the childs would change.  Similar workflow
to iParts but manual instead.
Kathy Johnson
Message 16 of 16
good point kathy ifeatures do not hold referential integrity
