I have attached an assembly, done in IV9, that uses an assembly to do
something like you have stated. I have started each of the parts by
deriving another part with only a length parameter, though you can have as
many parameters in it as you need. When the length parameter is changed in
the Part Parameter.ipt and the assembly updated the shaft and screw length
change together. Take a look and see if this helps out or at least gets
some ideas flowing for ya. This is similar to linking a spread sheet only I
have found it to be much more stable.
Do infants enjoy infancy as much as adults enjoy adultery?
IV 9 SP4 No extra Hotfixes
Win xp Pro SP2
Amd 3800 64 Bit
2 Gig Ram
Nvidia FX1000 7756driver
Corey Parks
Design Engineer
Metro Machine & Engineering Corp.
Eden Prairie, MN
cparks(A-T)metromachine(D-O-T)com
wrote in message news:5169840@discussion.autodesk.com...
Is a coil something that cannot be made adaptive? I have a screw auger
flight that I need to use over and over again, but at differing lengths.
After I created the coil, I went to change the feature to adaptive, and RMB
does not find that option. I thought a spring could be made adaptive, or is
that one of those things that really doesn't look right?
Is there a way to do this properly or not?
Thanks for your help,
Smoky IV10-SP3a
