Inventor General Discussion
Active Contributor
DevinCurrie
Message 1 of 4 (294 Views)
Action plan for dealing with 3d scan in point cloud format
294 Views, 3 Replies
09-19-2012 11:59 AM
Hello, I'm new to Inventor (currently using 2012) so I'm not too familiar with the software.
I have 3d scan of aircraft door frame (see attach) in point cloud format. I'd like to overlap 5 different frames and construct a new 6th frame by averaging out all of the points.
At the moment, the 3d data files has no surface and I'm unsure if adding surface is need to help with the construction of the 6th frame. I will also need to take into consider alignment, point density, and orientation when overlapping all of the frames before I can start work to average all points (Note: each scan are taken from 5 different vehicle).
If it help, I have both Rhino3D and Autodesk Alias Design 2012.
What are the logical steps to do in this case?
Thanks!
Devin
JDMather
Message 2 of 4 (290 Views)
Re: Action plan for dealing with 3d scan in point cloud format
09-19-2012 12:09 PM in reply to: DevinCurrie
It is unclear to me if this file includes all 5 scans or just 1 of the 5 (looks like the later case to me).
I don't know of an automatic Easy Button in Inventor to average the point locations.
Only way I know is to use them for visual reference and sketch using logical dimensions (most designers would use nice numbers, so it should be relatively easy to figure out the design intent within reason).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
DevinCurrie
Message 3 of 4 (285 Views)
09-19-2012 12:24 PM in reply to: JDMather
Sorry it is just one frame. I didn't include the others as it is similar except for orientation and small physical difference.
JDMather
Message 4 of 4 (281 Views)
09-19-2012 12:34 PM in reply to: DevinCurrie
Using them for visual reference I would edit the 3D sketch and select all the points with a window selection and toggle to points (rather than center-points).
I would go to Tools>Application Options>General tab and set Annotation scale to .2 (to make the points smaller as when you get 5 scans in there it will be pretty dense).
The rest is all manual labor to proceed.
I seem to recall that there is some new point cloud something or other in 2013, but even if there is (I just looked and couldn't find anything) I don't think it would be the Easy Button I suspect you are after.
Edit: just searched Google on Autodesk Inventor 2013 Point Cloud and got a bunch of Youtube hits - you might check them out.
