I wonder if I could export mulitple sheet drawings for a single part into a single Acrobat file. As of now I am only able to export one sheet at a time and also need to rename each Acrobat file though they belong to the same drawing.
Solved by Ollepheist. Go to Solution.
O hell, sorry I forgot I use 3rd party software to manage my pdf plotting.
That's exactly what I am looking for. How did you manage to do it ? If it is 3rd party software, what is the software ?
- Bye.
I use “Adobe Arobat 8 Pro” for all my Pdf printing. Inventor, AutoCad, Coral Draw, Office etc. Combining and renaming pdf’s (If needed) is easy enough with the necessary control over what happens to your pdf.
I would go for “Adobe Arobat 9 Pro” because you have more options where converting and combining AutoCad files are concerned.
