Inventor General Discussion
Valued Contributor
miketibbets
Message 1 of 5 (405 Views)
Acknowledged loft/shell issue Inv 2010
405 Views, 4 Replies
07-22-2010 10:15 AM
Hello all, thought I would pass on an acknowledged bug in a lofted/shelled solid in Inventor 2010. Bear in mind that I have been doing this workflow since Inventor 5.3  or so. Imagine my surprise when I installed 2010 and found out I had to workaround this issue as best I could. Imagine my larger surprise after talking with my reseller (good people) that Autodesk acknowledged the bug, but they have not issued a fix for it. This bug is not present in 2008 (previous release used) or 2011 (have not upgraded yet because of workload and a couple of other issues). This was acknowledged as a bug sometime in January 2010. Open the attached loft1.ipt and pull down the EOP. edit sketch1 of Loft1. change the 3 to 3.5 and the 5 to 5.5 and see what happens to the corners. I am told that Inv 2011 does not have this bug, only Inv 2010. I will stop now before I really get going on a rant
Mike Tibbets
Distinguished Contributor
lama
Message 2 of 5 (395 Views)
Re: Acknowledged loft/shell issue Inv 2010
07-22-2010 11:02 AM in reply to: miketibbets
hmm...that's weird.
Work around was fairly simple, but it the way you've done it seems the most logical to achieve your end result and that way is obviously not a proponent of change.
Larry Marshall
2013 Product Design Suite Ultimate
Windows 7 Sp1
Intel(R) Core (TM) i5-2400 @ 2.00GHz
6.00 GB of RAM
AMD Radeon HD 6570
Employee
johnsonshiue
Message 3 of 5 (384 Views)
07-22-2010 11:51 AM in reply to: miketibbets
Hi! Indeed, I see no reason why this case should fail. I have forwarded it to development for review. Regarding how to make it work for now, there are two workarounds I can think of.
#1, Edit the loft->check Merge Tangent Faces.
#2, Instead of creating shell, create an offset surface and split or sculpt the body to hollow it.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Valued Contributor
miketibbets
Message 4 of 5 (379 Views)
workarounds
07-22-2010 12:06 PM in reply to: johnsonshiue
I agree, there are multiple ways to work around this issue, which is what I have been doing for the last ummmmm 7 months. If was the finished product, that would not be a problem, however this is the beginning of the solid, and other features are added, etc. Workarounds are just that, more work to get around the issue.
Thanks for your response
Mike Tibbets
Valued Contributor
miketibbets
Message 5 of 5 (302 Views)
08-13-2010 05:24 AM in reply to: johnsonshiue
Johnson, first of all, thanks for your initial response. Have you heard any news about the status of this issue?
Thanks in advance
