I have been using inventor to model a few chair designs, i assume at some point i accidentally pressed a hot key as my design (made in one part) is now around 50% transparent and it is also transparent when rendered. Any feedback is appreciated.
Solved by blair. Go to Solution.
Not sure what you did, I just cleared all the appearance overrides on your chair. It's located at the very top of the menu bar, small little color wheel with a red X on the lower RH corner. Select it, then use the Clear All Overides.
