So because you don't need it there should be no improvements made to the Mechanical
programs? There is still a lot of people that haven't moved to Inventor that could use a
tool like this to help them get over the hump. The more people using Inventor and
eventually making the switch the more development AD can afford to pump into Inventor.
Call me crazy but I see it as a good thing even though I probably won't use it.
Besides they are two separate development groups, and the Mechanical group is by far
dwarfed from the Inventor group. You didn't loose anything in IDW development because of
Mechanical DX.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Andrew Pawelski"
wrote in message
news:719663237279952DD87776C0C0B7B1C8@in.WebX.maYIadrTaRb...
> I agree with Sean 100%, this is movnig backwards. I think that this DX
> setup, whatever is behind it, will be sloppy at best. This is all time that
> should be pumped into IDW improvement.
> Andrew
