Solved by johnsonshiue. Go to Solution.
I also would like to mention I realize this isnt the A360 area but since the main program I'm using is inventor I figured it would be safe to ask here. Still dealing with the same problem. I can view parts all day long but not assemblies (.ima)
Hi! When you upload the assembly (iam) file, did you upload the part (ipt) files the assembly references? The iam file alone cannot be opened successfully.
Could you do an experiment for me? I assume you have access to Inventor. Please download the iam file to a folder on your PC other than the one you originally uploaded to A360. Then try opening the iam file in Inventor. What do you see?
Thanks!
My sincerest apologies for taking a week to get back on her with a response. I got caught up in another project that kept me away from this one. You guys were 100% correct though! I cleared everything off my 360 drive and started over pulling everything from the assembly over (all component files) and sure enough it worked!
My only suggestion to autodek personel would be to display some kind of pop-up window that informs the user of this error. For a newbie I was lost until you guys responded because all it would do is load a blank screen still showing the tools for rotating the (what would be) assembly.
Thanks again for all of your responses you guys were very helpful!
Jeff
It wouldn't be any different on your own computer. If all you had was the single IAM file without the related IPT files you wouldn't be able to view your model in Inventor.
